Hi. In the Gauge feature of Ops Dashboard, is it possible to display the measured % value to a decimal place? I can express the threshold % in this way (e.g. 97.5%), but the measured value remains at 97% even though the gauge appears red when the value is
1274
02-10-2017 01:28 AM
MattFarthing
New Contributor II
Referring to the attached image, is it possible to express the measured % figure (97% in this instance) to a greater level of accuracy (i.e. at least one decimal place)?
GlenOlli
I think it is not possible to make it more accurate than that, since that field its calculated automatically and you do not have the possibility to manually manage that field type or to make it from a full number to a number with decimals.
Regards,
