Help with Arcade Expression
1161
03-18-2019 10:05 AM
Miguel-Fernandez
Hello all,
I have a map with two polygon layers and a point layer. One polygon layer is isochrones representing how far someone can go on public transit using current schedules. The second polygon layer is isochrones representing how far someone can go with increased frequency. The point layer contains points of interest. Some of these points can be reached by both polygons, some are only reached by one polygon, and some are not reached by either polygon. I'm trying to build an expression that I can use in the pop-up that will tell the viewer if that point can be reached using the current schedule, the increased frequency schedule, both, or neither. Below is the expression:
var current = FeatureSetByName($map,"Jane with Current Schedules")
var increased = FeatureSetByName($map,"Jane with High Frequency")
var Jane_current = Intersects($feature,current)
var Jane_increased = Intersects($feature,increased)
var both_Janes = Iif(Jane_current == Jane_increased,'true','false')
When(both_Janes == 'true','This location can be reached by Jane using the current and increased frequency schedules.'
Jane_current == true,'This location can be reached by Jane using the current public transportation schedules.',
Jane_increased == true,'This location can be reached by Jane using the increased frequency schedule.','This location cannot be reached by public transportation.')
When I try to run this, I get the following error: Parse Error:Line 9: Unexpected identifier
If I put a Count function around the intersects, it returns the correct count, so I'm confused why I'm getting an error on Line 9 when I call Jane_current in the When function.
Any help would be appreciated.
Miguel
Miguel Fernandez
KenBuja
MVP Honored Contributor
You're missing a comma at the end of this line
KenBuja
Miguel-Fernandez
Ken,
Thank you so much for spotting that!! I can't tell you how many times I went through this.
Miguel
Miguel Fernandez
Miguel-Fernandez
I will say that my expression does not produce the desired results. All points say that "This location cannot be reached by public transportation." So if you come across this post and know what might be causing that, feel free to let me know!
Miguel Fernandez
KenBuja
This works properly in the Arcade playground, changing the various permutations of true and false
var Jane_current = true;
var Jane_increased = true;
var both_Janes = Iif(Jane_current && Jane_increased,true,false)
When(both_Janes == true,'This location can be reached by Jane using the current and increased frequency schedules.',
Jane_increased == true,'This location can be reached by Jane using the increased frequency schedule.','This location cannot be reached by public transportation.')‍‍‍‍‍‍‍‍
