Hello, i need to help. I want to make a map in ArcGIS online. I got point layer with animals in one zoo. Is there any way how to make, that in every pop-up window will be a picture of that animal? I can only add one picture that shows in all pop-up window
3385
05-20-2016 11:33 AM
OndrejJizba
Hello, i need to help. I want to make a map in ArcGIS online. I got point layer with animals in one zoo. Is there any way how to make, that in every pop-up window will be a picture of that animal? I can only add one picture that shows in all pop-up windows. Thanks for answer, bye.
DanPatterson_Retired
check the help topics for such things as popups Configure pop-ups—ArcGIS Online Help | ArcGIS
AdrianWelsh
MVP Honored Contributor
Hi Ondrej,
Do you have an attribute field with an image url for each feature in your feature service? If so, you can include that field as your image. Take a look at the link Dan shared and click on Show Images:
http://doc.arcgis.com/en/arcgis-online/create-maps/configure-pop-ups.htm#ESRI_SECTION1_B16A9E11A48D4...
