GeoJSON layer questions in the new map viewer
1201
12-09-2021 10:41 AM
Royce_Simpson
GeoJSON is now supported in the map viewer but I can't get it to work.
When I go to add a new layer to a map and choose the geojson option, it allows me to put in a URL.  I've tried several and can't get any to work.  I get an error that says, "missing or not supported GeoJSON object type".
Here is a sample URL that I'm trying to map.  Does anyone know what the hangup is?  I actually ran this same URL in the early adopter map viewer a few days ago and it worked fine.  In fact, I can open the early adopter map viewer and run that same URL and it works.  Not sure what's different now.
ZaraMatheson
Hi Royce, We should have a fix for this in the next day or two. In the meantime, it should work if you separate out the parameters. Thanks for reporting!
Royce_Simpson
Thanks Zara.  That works.
-r
ZaraMatheson
Hi Royce, This should be fixed now so you don't have to separate out the parameters.
