GEOFORM
1757
5
12-20-2020 03:55 AM
BülentUysal45
Hello, I want to create a geoform but I cannot create a subtype field. the first column should have options, but it doesn't look like that. it looks like a normal text forehead. how can i fix this?https://6grup.maps.arcgis.com/apps/GeoForm/index.html?appid=bf64b1a9301445ba825b590de6b9df87
DavidPike
MVP Notable Contributor
Hi, I'd never heard of Geoform before, it looks like it could be quite useful, thanks.
Does you feature have subtypes/domains initially? If so, do they work in the normal editing widget?
BülentUysal45
i created a .csv file and imported it into arcgis online
BülentUysal45
DavidPike
I'm not sure you can create the subtypes from within Geoform, but only having heard of it today makes my opinion on this almost worthless.  I also don't think you can create the subtypes in AGOL (though again I don't use it).
Perhaps this may be of use to you - Define attribute lists and ranges—ArcGIS Online Help | Documentation
BülentUysal45
Merhaba, bir jeoform oluşturmak istiyorum ancak bir alt uç alanı oluşturamıyorum. ilk sütunun boyutları, ancak öyle görünmüyor. normal bir metin alnına benziyor. bunu nasıl düzeltebilirim? https://yadi.sk/i/Y1AQqAH4H-5gYw   https://6grup.maps.arcgis.com/apps/GeoForm/index.html?appid=bf64b1a9301445ba825b590de6b9df87
