Formatting ArcCade Expressions in Field Maps
746
02-28-2023 06:59 PM
by Anonymous User
Not applicable
Hello,
I simply wanted to do text formatting expressions in the Description box in Field Maps and does not seem to work. I've used the following for example just to have bold text:
<BOL>Example</BOL>
I can't find anything in the web. I'd think for sure there is some sort of tag or expression to format text in Field Maps. Any thoughts or ideas on this? Thanks so much.
Tom
DamonBreen
I believe what you are looking for is a custom pop-up display. In map viewer classic, click the three dots next to the feature that you want to make the custom pop-up for, and select "Configure pop-up". A new pane will appear, and under "Pop-up Contents" there is a dropdown list that should by default say "Display: A list of field attributes" change that to "A custom display" and then select the big green button for "Configure" and here you can type whatever you want to be displayed, and use dynamic text to reference fields of the selected feature.
by Anonymous User
Not applicable
Damon,
Probably correct. I assumed pop-ups was not the correct way. I'll give 'er a go soon. Thanks so much!
Tom
