Find HotSpots Failing
434
03-22-2013 02:48 PM
ClemHenriksen
New Contributor II
tried to create hotspots with two different CSVs. also tried to create with both drag-an-drop to web map, and web map using a featuservice. all get same error msg.
worked yesterday.
D&D - http://bit.ly/YuocdO
FeatService, small data set - http://bit.ly/Yuokdg
FeatService, larger data set - http://bit.ly/YuopxB
thanks.
AshleyPengelly
New Contributor III
Hi Clem,
Thanks for testing.  Since this worked yesterday for you and there was an update last night, can you try clearing your browser cache and try again?  If this does not work, can you send me the csv files that you are working with? Thanks Ash, apengelly@esri.com
LaurenScott
Ash and I tried a csv file and it worked fine.  Hopefully clearing the cache will do the trick ?
Lauren
