Filter based on two out of three possible values
1151
03-20-2023 11:53 AM
NoahWasserman
I need to filter based on two similar types of data. I've got "Inspection type 1", "Inspection type 2", and "Maintenance" as options for a Type field.  I need to be able to filter by "Inspection type 1" or "Inspection type 2" so I can calculate when the next inspection will need to be done. I previously had one inspection type so to filter I used...
var type = "Inspection"
var relatedfeatures = Filter(related,"Report_type = @type")
...but now I have two. They'll be used in the same way, but I need to be able to list all inspections.  How do I put two different variables into "Report_type = @type"?
Teresa_Blader
Ah, I see. So you want the filter to ask "if it contains the word "inspection"", correct? vs "if it equals"... since the different types are all in one field.
I think you would write Filter(related,"Report_type LIKE '%inspection%'"). Filter uses SQL92 language... but I'm not quite sure if that would be... LIKE '%inspection%' or something else.... if that's the case you'd skip var type and just write out the expression maybe? SQL is always a little tricky to me! 🤔
Teresa Blader
Olmsted County GIS
GIS Analyst - GIS Solutions
Teresa_Blader
I don't have time to build you out and test a full code... but I wonder if you could write an if else statement for which Filter expression gets used. Likeif (inspection type 1 == type) [relatedfeatures = filter(related, "Report_type" @type1)] else if (inspection type 2 == type) [relatedfeatures = filter(related, "Report_type" @type2)] else relatedfeatures = ''
(define type1/type2 variables first)
I probably have the variable names in the wrong spot, not sure where "related" comes from or "Report_type" or which table your inspection fields are in. But maybe the concept is worth playing around with.
Teresa Blader
Olmsted County GIS
NoahWasserman
Here is my code...I'm hung up on creating a large if structure when there could be a simple solution:
//pulls inspection frequency in days
var last = $feature.InspectFre
var adddays = Decode(last,"Annual", 365, "3 years", 1095, "Weekly", 7,0)
//establishes a start date for anything that doesn't have a previous inspection
var start = Date(2023,0,1)
//Pulls all inspection reports for this site
var ordered = OrderBy(FeatureSetByRelationshipName($feature, "InspectionReports"), "i_site_date DES")
var site = $feature.DBID
var related = Filter(ordered, "DBID = @site")
//there are three options, 'maintenance', 'septic inspection', and 'holding inspection'. The same calculation happens below, but I want to update from the singular 'Inspection' to either 'septic inspection' or 'holding inspection' so we pull just the inspection reports, order them, and count them.
//calculates next inspection date
var info = First(relatedfeatures)
var cnt = Count(relatedfeatures)
var relatedinfo = iif(cnt > 0, Text(DateAdd(info.i_site_date,adddays,'days'), "MM/DD/Y"), Text(DateAdd(start,adddays,'days'), "MM/DD/Y"))
return relatedinfo
Teresa_Blader
Teresa Blader
Olmsted County GIS
Teresa_Blader
Maybe you could alternatively write Filter(related, "Report_type = 'septic inspection' || Report_type = 'holding inspection'")
|| is OR in if else statements... might need to be OR in Filter SQL92
Teresa Blader
Olmsted County GIS
NoahWasserman
Thank you. I think this is working.  For anything with %Inspection it looks up last inspection, for anything 'maintenance' it adds the inspection frequency to 1/1/2023.
