Field Maps - calculate based on GPS metadata
151
07-30-2024 07:28 AM
mikAMD
In Field Maps, I realize that you can set a precision constraint in the mobile app based on the external device.
But I'm wondering if it's possible to only show some questions/fields based on metadata from the connected device?
For example, I would wish to make visible a certain question based on the fix type or even the correction age. I tried setting a simple arcade expression to the the visible parameter in my form ($feature.esrignss_correctionage < 2), but it doesn't seem to work and what I'm thinking is that this is normal because the field is not populated yet.
How does one get the GPS metadata on the fly with arcade?
Thanks!
mikAMD
Yes I know I can record them. What I wish to do is get them on the fly, before recording them.
There may be a way because in Field Maps you can set a constraint on precision, so the app does check this metadata with the external receiver. I'm just wondering if myself as a user there is a way to programatically get them with Arcade or something else.
Thanks!
