Feature Service 'Add to Definition' update domain
2085
09-05-2018 01:05 AM
StuartMoore
can i use the 'Add to Definition' REST api to update a domain on a feature service, i want to add in an additional value into the domain
Stu
KellyGerrow
Esri Frequent Contributor
You can also add coded value domains through a list of values from the data tab in ArcGIS Online. Check out these resources for more information:
Define attribute lists and ranges—ArcGIS Online Help | ArcGIS
https://www.esri.com/arcgis-blog/products/arcgis-online/uncategorized/whats-new-with-managing-field-...
MarisaClaggett
Hi Stuart,
You will have to use the Update definition operation.  I have included a link to a very helpful document outlining what can be updated via this definition, including domain values.
How To: Add coded value domains to a hosted feature service from a REST endpoint
Hope this helps!
Best,
Marisa
KellyGerrow
TheKenerson
    I was looking to define an attribute list using ArcGIS API for Python. I would think its a function tied to the Feature_Layer Object, but I cant seem to find it. The furthest i get is......
from arcgis.features import FeatureLayer
layer_url = 'https://servername.arcgis.com/OrrtI/arcgis/rest/services/TreeWorks/FeatureServer/0'
 layer = FeatureLayer(layer_url)
# Do a loop through all the fields in  the feature layer
for f in layer.properties.fields:
    print(f['name'])
This will get me to the feature layer field names but not sure where to go from there.
StuartMoore
this might help
Stu
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import arcpy
from arcpy import env
import os
env.workspace = "h:\Connection.sde"
datasets = arcpy.ListDatasets("*", "All")
# Write the name of the current fc in text file:
txtFileFC = open("H:\ListAll_FC.txt","w")
txtFileFC.write('Dataset|Type|FeatureClass Name|Record Count')
txtFileFC.write (os.linesep)
# Write the name of the current fields fc in text file:
txtFileFields = open("H:\ListAll_Fields.txt","w")
txtFileFields.write('Dataset|Type|FeatureClass Name|Field Name|Alias Name|Data Type|Required|Length|Domain')
txtFileFields.write (os.linesep)
# Write the name of Domains text file:
txtFileDomains = open("H:\ListAll_Domains.txt","w")
txtFileDomains.write('Domain Name|Domain Type|Coded Value|Alias Name|Min Range|Max Range')
txtFileDomains.write (os.linesep)
## List Features in Datasets
for dataset in datasets:
    for fc in arcpy.ListFeatureClasses('','',dataset):
        RecCount= '0'
##--- uncomment for counts
        arcpy.MakeTableView_management(fc, "myTableView")
        RecCount = arcpy.GetCount_management("myTableView").getOutput(0)
        arcpy.Delete_management("myTableView")
        # Write messages to a Text File
        txtFileFC.write(dataset+'|FC|'+fc+'|'+RecCount)
        for field in arcpy.ListFields(fc):
            txtFileFields.write(dataset+'|FCField|'+fc+'|'+format(field.name)+'|'+format(field.aliasName)+'|'+format(field.type)+'|'+format(field.required)+'|'+format(field.length)+'|'+format(field.domain))
            txtFileFields.write (os.linesep)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
#close text file
txtFileFields.close()
txtFileFC.close()
