Feature Display Order is not an option in Layer Properties pane (ArcGIS Online in new Map Viewer) - is there any way to change drawing order?
984
09-13-2023 07:32 AM
CathleenSampselle
In ArcGIS Online new Map Viewer I have a hosted feature layer that was published from Pro. ArcGIS Online does not honor the drawing order that was in the published layer and there is no option for 'Feature Display Order' in the layer Properties pane (screenshot below). I was also unable to change display order via the Visualization tab of the feature layer item. Is there any way to change the drawing order of the features in this layer?
RussRoberts
Esri Notable Contributor
Can you share the map and I can take a look why it is hidden.
Thanks!
