Failed to get administrator token from the server.Please verify that the ArcGIS Server URL specified can be accessed successfully in ArcGIS Server 10.5.1
9706
06-11-2018 08:21 PM
BethanyHall2
I am new to updating our server side of things and I received this error message after updating our ArcGIS Server from 10.2.2 to 10.5.1 while I was attempting to set up our web adaptor: Failed to get administrator token from the server. Please verify that the ArcGIS Server URL specified can be accessed successfully in ArcGIS Server 10.5.1
Can someone help me figure out what to do to get our web server up and running? I have a lot of angry folks needing services.
JakeSkinner
Esri Esteemed Contributor
Hi Bethany,
Are you able to access ArcGIS Server Manager through the following URL from the Web Server?
https://<server>.<domain>.<com>:6443/arcgis/manager
Also, did you uninstall the 10.2.2 Web Adaptor and install the 10.5.1 Web Adaptor?
BethanyHall2
Jake,
No, I was not able to access the ArcGIS Server Manager through the manager URL. So, I submitted a trouble ticket with ESRI and they helped me setup the manager account and configure the correct permissions.
Lastly, yes, I uninstalled the 10.2.2 Web Adaptor and then installed the 10.5.1 Web Adaptor.
AshokP
I am unable to access ArcGIS Server Manager/Server URL . Can someone please help?
pkaniouras
I am also unable to access ArcGIS Server Manager/Server URL . Could someone help us? I am using Version 10.9.1.
StevenEmbree_II1
I received this error as well. The issue was literally that the web adaptor was unable to reach the URL.
The web adaptor has a URL stored in a WebAdaptor.config file. The usual setup may have this file stored in the following directory:
C:\inetpub\wwwroot\arcgis
IMPORTANT: This directory may be different in your setup, please confirm with your ArcGIS administrator while troubleshooting.
This configuration file has URL entries hard coded into it. (See Below) If one or both of these URLs is/are a mismatch with the URL that the ArcGIS server is set up for, it may result in this error. In my case, the configuration file was accidentally modified manually. Restoring the URL to the correct format (in part by comparing to another functional server) resolved the error and restored access to ArcGIS Server Manager.
IMPORTANT: This is not a declaration that this is the precise issue in your case, but rather an explanation of what I found in mine. If possible, please explore this option with Esri Support to ensure that any trouble-shooting steps taken are supported. Also, before making any edits to any configuration files, ensure that the configuration file in question has been preserved in a backup.
SAMPLE:
<GISServer>
<Nodes>
<Node>someonesserver.organization.com</Node>
</Nodes>
<SiteUrl>https://someonesserver.organization.com:6443</SiteUrl>
I hope this helps! Good luck!
