Extracting id from MapView Object and then Making this Map available for everyone to view in Python.
2894
04-05-2021 08:36 AM
Labels (3)
findyourinvasive
Here is the code I have so far. I am using the ArcGIS Python API.
g = GIS("https://www.arcgis.com", "USERNAME", "PASSWORD")
p = {
'type':"CSV",
'title': '2020#12',
'snippet':'hwa',
'description':'test ' + \
'dataframe object to a GIS item',
'tags': 'python',
i=g.content.add (item_properties=p,
data="C:/Users/NAME/PycharmProjects/colors/Map/5TXHV8NTC5.csv"
q=i.publish ()
print (q)
search = g.content.search(query="owner:USERNAME",
item_type="Feature Layer")
print (search)
from arcgis.mapping import WebMap
#map = WebMap()
map=g.map (location="United States")
item=search [0]
print (item)
map.add_layer(item)
props={'title': '2020#156',
'snippet':'hwa',
'tags': 'python',
"renderer":"autocast",
"field_name": "Threat",
map.save (props)
1. I realize that I can get the id for the MapView object from the url. However, is there a way I can get this id from Python?
2. When I try an embed my map in my website, credentials are requested. I would like everyone to be able to view my map. Is there a way I can configure sharing privileges for my map from Python?
jcarlson
The MapView object may reference the web map, but is not the web map itself, so it won't have direct access to the id. Instead, you'll need to return the Item. You can pass the title you defined back into another query and get the ID that way.
map_id = g.content.search('new-title', item_type='Web Map')[0].id
Sharing is likewise defined at the Item level.
g.content.search('new-title', item_type='Web Map')[0].share(everyone=True)
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
findyourinvasive
I tried this:
map_id = g.content.search('2020#156', item_type='Web Map')[0].id
g.content.search('2020#156', item_type='Web Map')[0].share(everyone=True)
IndexError: list index out of range
The search comes up empty. However, it is in my contents (see image)
findyourinvasive
I converted the map to a web map and it worked perfectly. Thank you.
map = WebMap()
I also did
time.sleep(5)
It takes some time to update.
jcarlson
Great! I have noticed that searching for content can treat the '#' character differently, so perhaps that was involved. But as long as it's working!
- Josh Carlson
Kendall County GIS
