Expressions: IsEmpty shows same result in pop-up for every row
470
10-01-2021 03:55 AM
RaoulLeysen
Hello
I'm trying to hide empty fields in a pop-up with a expression:
var geboortedatum2 = "Geb. " + $feature.GEBOORTED2;
var overledendatum2 = "Overl. " + $feature.OVERLIJDE2;
IIf(IsEmpty($feature.OVERLIJDE2),"",geboortedatum2 + TextFormatting.NewLine + overledendatum2);
The pop-up doesn't seem to use my expression.
In the attachement you can see that it always shows the string info, regardless an empty row or not.
What am I doing wrong?
Thanks in advance!
JohannesLindner
MVP Frequent Contributor
Expression looks good. My guess would be that your "empty" fields aren't really empty (null or "") but have some value like " " in them.
Have a great day!
Johannes
JasonGlidewell
New Contributor III
I would suggest setting a variable for IsEmpty($feature.OVERLIJDE2) and console the output.
var empty = IsEmpty($feature.OVERLIJDE2)
Console(empty)
This will console either true or false.  Doing this, you may find fields you think are NULL are actually blank (AKA '').
Otherwise, I've also found setting the ImEmpty to a variable and using that as the test in the IIF works better.
Console(empty)
IIF(empty == true,'True','False')
Hope this helps!
