Expression using FeatureSet to add contextual data from another layer in pop-up not returning results
1411
9
05-10-2021 12:20 PM
FPGIS_FrancescaRohr
I am customizing the pop-up on my main layer (layer A) in a web map and want to include information from a separate layer (layer B). Both layers are point features. Layer A is tree points and Layer B is inspections on those trees, one inspection per tree. Not all trees have inspections. However, my expression is not returning the desired results.
Line 1 of my expression creates a unique id from two fields in layer A:
var treeuniqueid = Text($feature["Grant_ID"]+"_"+$feature["Tree_ID"])
Line 2 of my expression uses FeatureSetByName to access the attributes from layer B:
var inspection = FeatureSetByName($map,"UCF Tree Inspections - UCF Tree Inspections")
Line 3 adds in a filterStatement to match the records in layers A & B:
var filterStatement = "Tree_UniqueID = @treeuniqueid"
Lines 4&5 use Filter to only return the information for the selected tree point in the web map.
var inspected = Filter(inspection, filterStatement)
return inspected
In the expression window the results show that I am accessing layer B attributes:
but I get this in the pop-up itself:
Is using the created variable treeuniqueid to essentially 'join' the tables from the two layers an issue?
What else am I missing? Any and all help appreciated. Thank you, Francesca
XanderBakker
Esri Esteemed Contributor
Hi @FPGIS_FrancescaRohr ,
Sorry for the delay, but I was stuck in some meetings. I just had a look at the data and I think I have the answer. As you can see it now returns the  number of inspections:
There was just a tiny mistake in the expression. when you construct the SQL you use an underscore "_" when the data uses a hyphen "-". Also in my case the name of the layer was a bit different, but this could just be for me.
XanderBakker
The problem, in this case, is that you are returning a featureset to the pop-up. That is something the pop-up can't visualize. It does show in the expression builder, but this does not mean that it will show in the pop-up. You will probably have to loop through the features in the featureset and construct the text that you want to return.
Have a look at https://community.esri.com/t5/arcgis-online-documents/using-featuresetby-functions-in-arcade-to-dril... and the second code block where a list of maintenances of a hydrant is formatted and returned to the pop-up.
FPGIS_FrancescaRohr
Hello @XanderBakker
Thank you for the article link, it was very helpful. I simplified the expression from the article and customized it to work for my data:
var inspections = FeatureSetByName($map,"UCF Tree Inspections - UCF Tree Inspections")
var sql = "Tree_UniqueID = @treeuniqueid"
Console(sql)
var inspection = Filter(inspections, sql)
var cnt = Count(inspection)
var history = ""
if (cnt > 0){
history = cnt + "inspection(s):"
else {
history = "No inspections"
return history
I changed var sql from:
var sql = "Tree_UniqueID = '" + treeuniqueid + "'" to:
var sql = "Tree_UniqueID = @treeuniqueid" because I wasn't getting any return in my pop-up. Now I get 'No inspections' even when an inspection has occurred. Obviously var sql line is incorrect. I followed the example given for attribute related data in https://www.esri.com/arcgis-blog/products/arcgis-online/data-management/pump-up-your-pop-ups-with-ar...
I can't find any specific documentation on how to successfully create this variable. It's difficult to know the limits of Arcade - is there an issue with using a created variable as the 'field' on which to match (join) two data layers?  My hope is that I just haven't learned how to do it yet.
XanderBakker
Quick question: does your data use a Relationshipclass? If so, you are probably better off using the "FeatureSetByRelationshipName" to get to the related records.
FPGIS_FrancescaRohr
Hi @XanderBakker
No, the inspections are not a related table to the tree data.
XanderBakker
Sorry for the delay, but I was in meetings all afternoon. I was looking at the expression and I can't see any problem with it. I assume as you do that it concerns the SQL. I think you are creating it correctly, but I can't validate without having access to the data. In case possible, can you share the data? You could create a group, share the data to that group and invite me using "xbakker.spx" to the group.
Some minor changes to your expression, but none that will solve the issue.
var inspections = FeatureSetByName($map, "UCF Tree Inspections - UCF Tree Inspections");
var treeuniqueid = $feature["Grant_ID"] + "_" + $feature["Tree_ID"];
var sql = "Tree_UniqueID = @treeuniqueid";
Console(sql);
var inspection = Filter(inspections, sql);
var cnt = Count(inspection);
var history = "";
if (cnt > 0) {
    history = "inspection(s): " + cnt;
} else {
    history = "No inspections";
return history;
FPGIS_FrancescaRohr
Hi @XanderBakker
I have created an AGOL group - FROHR Private and invited you join. I have shared the UCF Tree Inspections layer and the CAL FIRE UCF Tree Data layer with this group. Both are views but should work for you.
I made the small changes to the expression and, as you expected, continue to get a return of  'No inspections' for every tree point.
I appreciate your help on this. Francesca
XanderBakker
FPGIS_FrancescaRohr
@XanderBakker  It's always something small! 😄 Nice job in spotting the teeny mistake which brought down the whole expression. And for pointing me in the right direction. Thank you very much! I can now use this as a base for adding additional, more complex, information from the contextual layer.
XanderBakker
I'm glad it was fixed. If you need some more help further along the line, don't hesitate to tag me.
