Experience Builder Connect Selected Feature to Survey123
556
04-16-2021 02:42 PM
GIS_utahDEM
Occasional Contributor II
Hello, I am new to experience builder and am trying to move over some capabilities that I use currently in dashboards. I have a survey and a map with the survey points in it. I want the people who have access to the survey/edit capabilities on the points to click on a point on the map, and auto-fill all the survey information from that point in the survey window, which they can then review or edit. This is a fairly simple action in dashboards to just filter the embedded content, but I'm not finding a similar option in experience builder. Am I missing something? Should I just continue using dashboards for now?
Background: I am playing with switching to experience builder because I have a lot of different groups and feature views with different edit access and I was thinking it may be easier to control who sees what (i.e. everyone doesn't need to scroll through a bunch of tabs to find their jurisdiction every time), but I could be wrong. I have also considered Hub, but really I want more options to filter list views and subsequently survey123 features.
jcarlson
This is definitely possible in EB!
Using an Embed widget, connect the embed to your layer. In the URL text box, use a similar URL as in your Dashboard. survey-url?mode=edit&globalId={GlobalID}
On the corresponding Map widget, add a trigger to Select Data Records when a feature is selected in the map.
The embed widget should reload when features are selected.
- Josh Carlson
Kendall County GIS
