Error uploading local zipped shapefiles to arcgis.com
551
05-31-2012 09:11 PM
StuSmith
Hi All,
All of a sudden, I am not able to upload any zipped shapefiles to my map using the "Add Layer From File" drop-down.  Weird.  I get the following message:
Error Unable to import this shapefile. (GenerateFeatures Service error Exception pub.arcgis.com)
Anyone have any ideas?  I've been loading the same shapefiles for days now, and all of a sudden this weird message.  Thanks!
by Anonymous User
Not applicable
Hi Stu,
Are you still having this problem?
If so, do you mind posting your shapefile to the forum so I can test it?
Cheers,
Andrew
boonejardot
Are the files in the same Datum?  If not a You may have to transform the datum using ArcCatalog.  Did you export the file OUT of the zipped folder that was SAVED do your harddrive??
