Error linking Google Sheet to webmap
4550
18
01-30-2020 09:27 AM
sdegroot
I used to link Google Sheets to a webmap just by publishing the Sheet, then adding it as CSV to my webmap. Two weeks ago, this worked fine. Today I get errors, with the same Sheets, which are still shared in the same way. When I try to add the Google Sheet as CSV I get an error that the Sheet 'is not accessible':
When I open a webmap that used to have Google Sheets linked as CSV I also get an error that the Sheet 'is not accessible':
Can anyone offer a work-around or tell me how I can get these sheets linked in to my webmaps again? We are using these to coordinate among a bunch of project partners, and not being able to see our data on the map is frustrating.
Thanks for your help.
by Anonymous User
Not applicable
Hi Kasimir,
Pop-ups are working on my end as well, I would definitely try Sarah's suggestion below. If this doesn't work I would contact Esri Support; they can take a closer look at the issue and see what is occurring with the pop-ups.
-Peter
KasimirOrlowski
problems solved! Thanks again for getting back to me!
by Anonymous User
Not applicable
Hello Peter,
I'm having this issue with publishing my Google Sheet into feature layer in AGOL. I've used 2 methods:
  1. Using the published CSV: https://www.esri.com/arcgis-blog/products/arcgis-online/data-management/using-google-docs-in-your-ar...
  2. Using the Google Sheet straight out of Google Drive: How To: Add and update Google Sheets data in ArcGIS Online
Neither worked. The first method came out with an error that says no location can be found:
And the second method just straight out pops 'There was an error':
I've remade my Google Sheet countless time and recheck. Everything seems to be alright. But the errors persists:
I don't know what I might be doing wrong. Any suggestions would be great.
Thank you!
Lea
by Anonymous User
Not applicable
Hi Lea,
The sheet has to be shared in CSV format to be added. For example, adding the Google sheet link directly will result in errors like those you are seeing above. For example, a valid URL might look like:
https://docs.google.com/spreadsheets/d/e/<longGUID>/pub?gid=0&single=true&output=csv
Hope this helps,
-Peter
by Anonymous User
Not applicable
Hello Peter!
Sorry. I tried it and it did not work. Even when I changed the URL to abide to the format you shared above.
I'll try and troubleshoot again.
Thanks!
by Anonymous User
Not applicable
Sounds good, Azalea. If you are able to contact Esri Support, they can help you troubleshoot it too.
Esri Support Contact Support
-Peter
wlavell
Hi
I am getting the same error.  When I try to update my googleSheet I just get an error that says
Error
Cloud drive file not found.
I have not changed the file name or made any changes.  I was in fact testing this to make sure that the functionality will work as needed. But it seems it does not
by Anonymous User
Not applicable
Hi @wlavell I can reproduce this. I've reached out to the Development team, it seems like a bug.
wlavell
Hi thanks for this
