ERROR 001270: Consolidating the data failed.
66707
61
07-30-2012 07:43 AM
YimanSong
I got this error when I try to publish a tiled map service to ArcGIS Online through ArcMap. Does anyone know why?
LanceSingleton
We also had the same error when creating a Extract Data Task (service) from data off of our sde. We made sure a data sources were registered, set staging to just C:\temp, and shortened the server connection name. No luck. We then created a File GDB with the features we wanted to export and the Extract Data Task was created just fine.
by Anonymous User
Not applicable
I got this error, and here's how: I had mistakenly moved one of my feature classes out of a feature dataset in the same geodatabase. ArcMap still saw the data, which surprises me, and which is why I didn't spot it right away, but I got the "Consolidating the data failed" error when attempting to publish. When I moved the feature class back into the feature dataset, everything worked fine.
A few more details for the curious: I didn't actually "move" the feature class. Actually, I recreated it. But I guess I forgot to specify that the recreated feature class should go in the feature dataset where the old feature class was. I couldn't just drag the recreated feature class into the feature dataset. I had to copy and paste with a new name, delete the old feature class, and rename the new feature class to the old name.
ToddHenry1
I'm getting this error message trying to stage the service via python.  It works fine if I just create a MapService, but when I add the following python to change it to feature service, I get this error:
#overwrite existing service
tagsType = doc.getElementsByTagName('Type')
for tagType in tagsType:
    if tagType.parentNode.tagName == 'SVCManifest':
        if tagType.hasChildNodes():
            tagType.firstChild.data = "esriServiceDefinitionType_Replacement"
tagsState = doc.getElementsByTagName('State')
for tagState in tagsState:
    if tagState.parentNode.tagName == 'SVCManifest':
        if tagState.hasChildNodes():
             tagState.firstChild.data = "esriSDState_Published"
# Turn off caching
configProps = doc.getElementsByTagName('ConfigurationProperties')[0]
propArray = configProps.firstChild
propSets = propArray.childNodes
for propSet in propSets:
    keyValues = propSet.childNodes
    for keyValue in keyValues:
        if keyValue.tagName == 'Key':
            if keyValue.firstChild.data == "isCached":
                keyValue.nextSibling.firstChild.data = "false"
#Create Feature Service
# Change service type from map service to feature service
typeNames = doc.getElementsByTagName('TypeName')
for typeName in typeNames:
    if typeName.firstChild.data == "MapServer":
        typeName.firstChild.data = "FeatureServer"
# Turn on feature access capabilities
configProps = doc.getElementsByTagName('Info')[0]
            if keyValue.firstChild.data == "WebCapabilities":
                keyValue.nextSibling.firstChild.data = "Query,Update"
It also works ok, if I creating the staging file through Share as Service through ArcMap.
ScottCarmine
I fought with this same issue for hours yesterday and tried everything suggested here to no avail. I finally figured it out this morning. Not sure if this applies to all instances though. In my case, I had brought feature classes from an SDE into ArcMap and was trying to publish to the server. I had renamed the layers to more map-user-friendly names other than the raw file names. This is apparently what was causing the issue. Once I changed the layer names back to match the file names in the SDE, I was able to publish with no problems.
Hope this helps somebody else!
CarmellaBurdi1
Thank you, Scott! This worked for me as well.
ChrisSmith7
Honored Contributor
I had an issue with this while publishing an xy event table from a view on a SQL Server direct connection. I'm not sure what worked in particular, but here are the actions taken to resolve:
1) Saved and closed MXD
2) Restarted MXD
3) Allowed full layer to render in ArcMap
4) File >> Share as >> Service
5) Elected to use an existing folder rather than create a new one
6) Analyzed service
7) Registered SQL db so data weren't copied to the server
😎 Published service
It worked well the second time around!
AlessandroValra
In my case, registering the datasource in the arcGIS Server data store (step 7) was the key step to solve the isse.
ChristopherSchreiber
I closed and then reopened ArcMap and then it worked.
I am using 10.2.2.
No Idea what changed.
by Anonymous User
Not applicable
I did something similar to Christopher. I opened a new ArcMap document and copied my features classes over to the freshly opened ArcMap document (Utitled.mxd). The service published immediately from the Utitled.mxd no problems or hiccups.
by Anonymous User
Not applicable
I found that if I set my data frame to display at the extent of all layers, rather than specifying a specific extent (ex.current view-able extent, or other layers) I was able to publish my service. This as well as a second error that occurred which required me to start an untitled arcMap doc,redefine extents, and symbology.
