Enterprise Login through Microsoft Teams Web Tab Error
1207
04-12-2018 02:51 AM
FinnianO_Connor
Occasional Contributor II
In Microsoft Teams I added a Website Tab which points to an ArcGIS Online Web App. When a user goes to this tab they are presented with the AGOL login page asking if they wish to use their Enterprise login or ArcGIS login. If ArcGIS login is chosen, the web app will load successfully. If Enterprise login is chosen the default browser (IE, Chrome etc) is opened with the error  "Unable to login using Idp client_id not specified. Error 400".
Wondering has anyone experienced this and does this error likely point towards ESRI, Microsoft or some internal settings issue?
Cheers,
Finnian
NicolasKLEIN
I had the similar problem.
My goal is to use Azure AD with ArcGIS Enterprise 10.6.1 but we had the same error when we try to connect to my Enterprise on Azure :
ArcGIS Portal Directory |
Error
Error: 400
Finnian O'Connor : do you find some help ?
Nicolas
AndresEcheverri
Hi @NicolasKLEIN and @FinnianO_Connor
Were you able to fix that problem?. I am experiencing the same issue.
Andres
