Elevation layers not being rendered in arcgis online
1928
7
05-12-2021 11:57 PM
Labels (3)
rayankothari
New Contributor II
I am trying to publish Elevation layers  created from aerial imagery  in arcgis online from arcgis pro.
the publishing part is successful but when I view it in the scene viewer there is no elevation in the map even though the layer has loaded without errors.
to confirm that the data does not have any problem I tried publishing the same data onto Arcgis enterprise with the same configurations  and thee it is working as expected.
I have attached the screenshot showing a elevation layer that is working on enterprise but not on arcgis online
RussRoberts
Esri Notable Contributor
Publishing the hosted elevation layer I see this with just the hosted elevation layer on and the world elevation disabled.
RussRoberts
Can you share the tpk that is generated when you publish to online?
Thanks!
rayankothari
New Contributor II
what do you mean by the tpk?
RussRoberts
It’s a tile package. To publish hosted elevation layers to AGO  the elevation tiles come from a tpk.  If you go under my content you should see your elevation layer and tpk associated with it.
rayankothari
New Contributor II
This is the tpk file(inside the zip) does this help?
RussRoberts
rayankothari
New Contributor II
thank you so much for your help !
can i know what spets you took to publish this ?
RussRoberts
If I remember correctly I published the tpkx you shared. I think you need to make sure you disable the world elevation in your web scene if you want to see it.
