I'm using elevation service(rest api) for building elevation surface.
Below image is a 3D surface using export map and elevation query.
I'm using the Base URL as https://elevation.arcgis.com/arcgis/rest/services/Tools/ElevationSync/GPServer/Profile/execut
Most of the sea area are just flat,
but, as you can see, the elevation of sea near the "Opera house" is higher then ground.
Is there any problem of data source? or Is there any option for elevation at sea?
