Hello,
I want to make a web map that includes a relationship class. Ideally, the users of the web map should be able to edit related records. I know that ESRI recently added the ability to "Show related records", but I don't see any capabilities to edit related tables in any way. Has anyone found a workaround for this? Is ESRI planning on releasing this functionality at a later date?
Brianna
Hi Brianna,
I realize this is an older post, but just to close the loop on this item. You can edit related records with Web AppBuilder that is embedded in ArcGIS Online. Please see the blog,
What’s New in Web AppBuilder for ArcGIS (September 2016) | ArcGIS Blog
Hope this helps,
To add onto Derek's post, there are a few other places in ArcGIS Online where you can edit related records.
It is possible to edit related records through the data tab on the details page. Check out this blog for more information:
The new Data tab: More than just a table (June 2016) | ArcGIS Blog
You can also edit and add related records using the Crowdsource Manager App:
http://solutions.arcgis.com/state-government/help/crowdsource-manager/
Cheers,
Kelly
