Edit pop-up location in AGOL web map?
706
6
04-25-2022 10:54 AM
EJhanekSzypulski
Hello all,
I've done a pretty extensive search but I can't find a way to change the pop-up location for an AGOL web map. Is it not possible?
Is there a way to default to a docked pop-up?
~Jhanek
jcarlson
You can go into the web map's JSON, using something like the AGO Assistant, and edit the popup settings, as detailed in this solution:
https://community.esri.com/t5/arcgis-experience-builder-questions/how-to-change-default-docked-popup...
EDIT: I replied too quickly, that won't help you in an AGOL web map. That setting isn't in the web map's JSON, but the viewer app itself, which you won't have access to in AGOL.
- Josh Carlson
Kendall County GIS
RussRoberts
Esri Notable Contributor
The dock popup in Map Viewer is stored on a browser cache basis and is not stored in the web map at this time.
Ed_
by MVP Regular Contributor
@RussRoberts Is it possible to change the popup location of a map using another app let's an Instant App template?
RussRoberts
You can adjust the docking placement in instant apps under the Step 2. About section.
Ed_
Cheers Russ, this helps 🙂
EJhanekSzypulski
Thank you both. I have created a web app instead of a web map. Is there a way to have the pop-up open docked by default?
