Easily allow Arcade Expressions to be added to a pop-up text in the new Map Viewer
561
10-18-2022 12:05 PM
RyanBohan
Map Viewer "Classic" pop-ups have an easily way to add Fields or Arcade Expressions.
The new Map Viewer "previously beta" does not include this option.  It appears you just type a "{" and then scroll down the list that shows up.  This is not intuitive; I randomly came across it.  Please add back the little plus sign.  Another option would be to add a help/info button to provide users information on how to use the pop-up editor.
My current workflow is just to make the edits in classic, and hope nothing breaks.
Tags (3)
jcarlson
MVP Esteemed Contributor
The new map viewer actually has a whole separate Arcade popup item now, so rather than adding a text item you pipe expressions and attributes into, you can have it all wrapped up into one thing. Personally, I find it a much nicer way of working with Arcade in the popup, and if you have multiple expressions you're working with, having them all execute at once can give you a performance boost, too.
- Josh Carlson
Kendall County GIS
RyanBohan
I see what you mean, thank you.  I am still getting use to the new map viewer.
