Hi Mike,
I'm having a problem where my dropdown field attribute values are unordered. Is there a way to make these values appear in alphabetic order?
Cheers,
Andy
Andrew,
What is the source of the data you're editing? If it is based on data where you have domains set up (i.e., published from ArcGIS Desktop), then the order comes from the order the domains were created. There is a desktop tool to reorder domains, called sort coded value domains.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
This sorting would have to be done before publishing the data to ArcGIS Online or your own ArcGIS Server. There is no ability to sort these values in the map viewer of ArcGIS Online.
Mike
Hi Mike,
Yes the data was published from ArcGIS Desktop. I've since done as you suggested - drop down menus now alphabetised in AGOL. Many thanks for your help.
Andy
