Domain names in Arcade for Pop-up (New Map Viewer/Experience Builder)
3271
6
06-09-2021 01:15 PM
Ramon_de_Leon
Is there a glitch in displaying domain names in the "New Map Viewer" and "Experience Builder"?
I have the script below for my pop-up, it displays correctly when the map is viewed in the "Classic Map Viewer" and WebAppBuilder, but when viewed in the "New Map Viewer" and "Experience Builder" the domain name becomes blank (see screenshot of popup comparison at the end of the post)? The pop-up is also previewed correctly when tested on the custom pop-up expression window.
Was hoping to be able to use the "New Map Viewer" and "Experience Builder", but the popup is an essential thing that I need in my design.
Will appreciate any solution or workaround.
var project_1 = 'Project: ' + DomainName($feature,"WORK_TYPE_1") + TextFormatting.NewLine + 'Description: ' + $feature["PROJ_DESC_1"] + TextFormatting.NewLine + 'Start Date: ' + Text ($feature["PROJ_START_1"], 'MMMM DD, YYYY') + TextFormatting.NewLine + 'Target Completion Date: ' + Text ($feature["PROJ_END_1"], 'MMMM DD, YYYY') + TextFormatting.NewLine + 'Project Status: ' + DomainName($feature,"WORK_STATUS_1") + TextFormatting.NewLine + '<br /><a href="' + $feature["HYPERLINK_1"] + '" target="_blank">Click link for more info</a>'
var project_2 = TextFormatting.NewLine + TextFormatting.NewLine + TextFormatting.NewLine + '------------------------------------------'+ TextFormatting.NewLine + 'Project: ' + DomainName($feature,"WORK_TYPE_2") + TextFormatting.NewLine + 'Description: ' + $feature["PROJ_DESC_2"] + TextFormatting.NewLine + 'Start Date: ' + Text ($feature["PROJ_START_2"], 'MMMM DD, YYYY') + TextFormatting.NewLine + 'Target Completion Date: ' + Text ($feature["PROJ_END_2"], 'MMMM DD, YYYY') + TextFormatting.NewLine + 'Project Status: ' + DomainName($feature,"WORK_STATUS_2") + TextFormatting.NewLine + '<br /><a href="' + $feature["HYPERLINK_2"] + '" target="_blank">Click link for more info</a>'
var project_3 = TextFormatting.NewLine + TextFormatting.NewLine + TextFormatting.NewLine + '------------------------------------------' + TextFormatting.NewLine + 'Project: ' + DomainName($feature,"WORK_TYPE_3") + TextFormatting.NewLine + 'Description: ' + $feature["PROJ_DESC_3"] + TextFormatting.NewLine + 'Start Date: ' + Text ($feature["PROJ_START_3"], 'MMMM DD, YYYY') + TextFormatting.NewLine + 'Target Completion Date: ' + Text ($feature["PROJ_END_3"], 'MMMM DD, YYYY') + TextFormatting.NewLine + 'Project Status: ' + DomainName($feature,"WORK_STATUS_3") + TextFormatting.NewLine + '<br /><a href="' + $feature["HYPERLINK_3"] + '" target="_blank">Click link for more info</a>'
var project_2_extra = IIf(($feature["WORK_STATUS_2"] == 'planned' || $feature["WORK_STATUS_2"] == 'ongoing'), project_2, '')
var project_3_extra = IIf(($feature["WORK_STATUS_3"] == 'planned' || $feature["WORK_STATUS_3"] == 'ongoing'), project_3, '')
var popup_info = project_1 + project_2_extra + project_3_extra
Return popup_info
Ramon_de_Leon
Hi @JohnPlunkett , was trying it in AGOL last year.... just tried again now and the domain names are displaying correctly on the pop-ups on the "New Map Viewer" and also when it used in WAB & Experience Builder... Good to know, thank you....
KenBuja
MVP Esteemed Contributor
There does seem to be a glitch.
Nothing is returned using the domain
return "Domain: " + DomainName($feature,"FishStatus") + TextFormatting.NewLine
       //+ "Value: " + $feature.FishStatus;
 If I add in the actual value, then the Domain value shows up:
Ramon_de_Leon
Thanks for testing.
It's weird that when you added the both domain value and name on the the arcade script it displayed correctly.
Hope Esri gets a fix soon.
KenBuja
Don't rely on them reading this thread to fix it. If you can, open a support case to bring it to their attention.
kmsmikrud
Wow you nailed the issue right away with the domains in the arcade. I went back and forth between classic and the new map viewer and couldn't figure out what is going on. Did you figure out a work around or submit a tech case on this? If not I will submit one and reference your post. What a bummer on this.
JohnPlunkett
Were you using ArcGIS Online or Enterprise 10.9.1 - It appears to be working for me
Ramon_de_Leon
