Does the esri Clarity Imagery work as an offline basemap?
404
05-02-2019 01:46 PM
RoyceSimpson
Occasional Contributor III
Does the Clarity layer (as a basemap) not work with web maps offline in Collector? If I choose the regular esri imagery layer as my basemap, the webmap can be set for offline use. If I choose the Clarity basemap, the offline capabilities go away. What am I doing wrong?
x (x)
RussRoberts
Esri Notable Contributor
Currently this does not support export tiles. On the layer item you will see a note in the terms of use that export is not supported
"Export: This layer is not intended to be used to export tiles for offline."
http://www.arcgis.com/home/item.html?id=ab399b847323487dba26809bf11ea91a
RussRoberts
RoyceSimpson
Indeed.  Thanks Russell.  Not only is it "not intended" to be used for offline it's not possible. Drat.
x (x)
