Hi all,
I would really want to use Forms in the Map Viewer, however, I can't seem to find any information about what happens to the Form, if I overwrite the Web layer from within ArcGIS Pro?
Sometimes we make changes to our layers in our database, and then overwrite the published web layers - i know that it destroys custom settings etc that I have made on the layer in the Web map, but does it also destroy the Form?
And in a related though, it seems that it is not possible to save a Form, so that it could be applied to another identical layer - is that correct?!
Thanks 🙂
I also have this question! I have a ton of form customizations and Arcade expressions to support the Editor tool in Map Viewer, but now I need a schema change. It would be so awesome if we could save our Form customizations and apply them to other layers.
Have you messed around with AGO Assistant? I just figured out how to copy and paste the JSON form info between layers and it is incredibly helpful if you have the same form for multiple layers.
