Does AGOL run on Linux or Windows?
511
06-01-2022 11:38 AM
Brian_Wilson
Honored Contributor
I assume that AGOL runs on a cloud platform like AWS or Azure.
Is it running on Windows or Linux?
The reason I ask is because I am curious whether Esri has reached that level of confidence in running their flagship product on Linux or if they are still using Windows Server?
Brian_Wilson
Honored Contributor
Indeed that would answer the question.
Doing nslookup on the ip addresses shows AWS for several of the arcgis.com nodes I checked. I also looked at our own *.maps.arcgis.com and got the same answer.
So I am going to mark it as "runs on Linux". This warms my heart.
Thanks for the suggestion.
Waffle_House
AWS would be linux and Azure would be MS so you're asking if it uses AWS or Azure?
Brian_Wilson
Honored Contributor
