Displaying images in popup
1626
08-07-2014 06:38 AM
RebeccaMiller
I've created a map in ArcGIS online, and have added images the the popups using their URLs.
At the moment, when I embed the map and click on the feature, the text appears in the popup first, followed by the image. My question is, is it possible to change the order so that the image appears first in the pop up and then the text?\
Many thanks
MikeMinami
Esri Notable Contributor
My previous answer was not correct really. You can use the Custom popup option, which effectively allows you to configure the layout of the popup as you like. I'm not sure what I was thinking before when I answered this...
**** Original Response ******
No, this is not possible with popups in the out-of-the-box app. . The only thing you can do is remove the text and only show the image. Now, you can probably write your own application to do this. You'd have to be a programmer and use our Javascript API or other API...
Mike
RebeccaMiller
Ok, I'm not at programmer level so will stick with the image at the bottom!
Thanks
Becs
DanielleReeder
Here is a pretty good description of how to configure the pop-ups without programming: https://community.esri.com/message/622717?commentID=622717#comment-622717
