Display related records in a popup in a nice table
4203
14
03-21-2023 12:22 PM
NorthSouthGIS
I have a table of related work history on a point asset layer. For each point representing an asset, there are multiple related records storing the work history. Here is the Arcade expression I used to display in the pop up.
Note: This only works right now when set up as an Arcade Expression content type, rather than an arcade expression referenced in a Text content type.
// Get the related work orders
var includedFields = ['Type','completion_date','real_price'];
var history = FeatureSetByRelationshipName($feature, 'relationshipName', includedFields);
if (count(history) > 0){
  // Get the schema of the WorkOrders table
  var woSchema = Schema(history);
  // Get the fields from the schema
  var fields = woSchema.fields;
  // Define an array to store the table headers
  var headers = [];
  // Loop through the fields and add a header to the array for each one
  for (var i in fields) {
    var field = fields[i];
    if(Includes(includedFields, field.name)) {
      Push(headers,'<th style="border: 1px solid #ddd;padding: 8px;background-color: #eee;">' + field.alias + '</th>');
  // Define the HTML table header row
  var headerRow = '<tr style="border: 1px solid #ddd;padding: 8px;">' + concatenate(headers) + '</tr>';
  // Define an array to store the HTML table rows
  var rows = [];
  // Loop through each related work order and add an HTML table row to the array
  for (var i in history) {
    var wo = i;
    // Define an array to store the data for the current row
    var rowData = [];
    // Loop through the fields and add the value of each field to the rowData array
    for (var j in fields) {
        //Skip Object ID Field
        if(fields[j].alias != 'OBJECTID_1') {
          Push(rowData, '<td style="border: 1px solid #ddd;padding: 8px;">' + wo[fields[j].name] + '</td>');
    // Concatenate the rowData array into a string with table data tags
    var row = '<tr style="border: 1px solid #ddd;padding: 8px;">' + concatenate(rowData) + '</tr>';
    // Push the resulting string into the rows array
    push(rows, row);
  // Define the HTML table using the header row and the rows array
  var table = '<p><h3>Work History</h3></p><div><table style="font-family: arial, sans-serif;border-collapse: collapse;text-align: left;">' + headerRow + concatenate(rows) + '</table></div>';
  // Return the HTML table
  return {
	type : 'text',
	text : table //this property supports html tags
//return table;
} else {
  return {
	type : 'text',
	text : '<p><h3>Work History</h3></p><p>No related work history</p>' //this property supports html tags
e_huynh161
How did you get 2 separate tables?
Marshal
Using a loop to build multiple tables as needed and pushing them into a list.  Then concatenating all tables from the list for the return statement.  Here is my working code, hope it helps!
Again, thanks to @NorthSouthGIS for inspiring the solution that worked for me.
// Establish a connection to the ArcGIS Portal
var portal_con = Portal('https://gis.domain.com/portal');
// Retrieve a feature set by Portal item ID and select relevant fields
var fs = FeatureSetByPortalItem(portal_con, '9d41bd4a518947a28ac549d48f1a6539', 0,
    ['LEASE_NUMBER', 'COMPANY_NAME', 'ASGN_PCT', 'ALQT_ID', 'DESCRIPTION', 'AREA_BLOCK']);
// Active feature lease number for defining the filter
var lease = $feature.Lease;
// Define the query string to filter records based on the active lease
var lease_filter = 'LEASE_NUMBER = @lease';
// Filter the feature set using the lease filter
var records = Filter(fs, lease_filter);
// Initialize an empty list to store unique ALQT_IDs and a dictionary for descriptions
var alqs = [];  // List to hold retrieved ALQT_IDs
var descs = {};  // Dictionary to map ALQT_ID to legal descriptions
// Loop through the filtered records to populate ALQT_IDs and their descriptions
for (var record in records) {
    // Construct a description based on the record's DESCRIPTION and AREA_BLOCK
    var desc = '';
    if (IsEmpty(record.DESCRIPTION)) {
        desc = 'All of lease ' + lease + ' within block ' + record.AREA_BLOCK;
    } else {
        desc = record.DESCRIPTION + ' of block ' + record.AREA_BLOCK;
    // Store the description in the dictionary, keyed by ALQT_ID
    descs[record.ALQT_ID] = desc;
    // Add the ALQT_ID to the list
    Push(alqs, record.ALQT_ID);
// Remove duplicate ALQT_IDs to ensure uniqueness
var alqs = Distinct(alqs);
// Initialize an empty list to hold the generated HTML tables
var tables = [];
// Check if there are any ALQT_IDs to process
if (!IsEmpty(alqs)) {
    // Loop through the distinct ALQT_IDs
    for (var alq in alqs) {
        var curr_alq = alqs[alq];  // Current ALQT_ID being processed
        var alq_filter = 'ALQT_ID = @curr_alq';  // Query string for filtering by ALQT_ID
        var alq_records = Filter(records, alq_filter);  // Filter records by the current ALQT_ID
        // Fields to be included in the output table
        var data_fields = ['COMPANY_NAME', 'ASGN_PCT'];
        // Initialize an empty list to store the HTML rows for the current table
        var rows = [];
        // Loop through the filtered records for the current ALQT_ID
        for (var alq_record in alq_records) {
            var row_data = [];  // Initialize a list to hold the data cells for the current row
            // Loop through the data fields to build each cell
            for (var field in data_fields) {
                Push(row_data, '<td style="border: 1px solid #ddd;padding: 8px;">' + alq_record[data_fields[field]] + '</td>');
            // Combine the cells into an HTML row and add it to the rows list
            var row = '<tr style="border: 1px solid #ddd;padding: 8px;">' + concatenate(row_data) + '</tr>';
            Push(rows, row);
        // Define the header fields for the table
        var header_fields = ['Company', 'Interest'];
        var headers = [];  // Initialize a list to hold the header cells
        // Loop through the header fields and create styled header cells
        for (var header_field in header_fields) {
            var field = header_fields[header_field];
            Push(headers, '<th style="color:black; border: 1px solid #A9A9A9;padding: 8px;background-color: #eee;">' + field + '</th>');
        // Combine the header cells into an HTML header row
        var headerRow = '<tr style="border: 1px solid #A9A9A9;padding: 8px;">' + concatenate(headers) + '</tr>';
        // Construct the full HTML table, including the description and rows
        var table = '<h7><b>' + descs[curr_alq] + '</b></h7>' +
                    '<table style="font-family: arial, sans-serif;border-collapse: collapse;text-align: left;">' +
        // Add the table to the list of tables
        Push(tables, table);
    // Combine all tables into a single output string, separated by line breaks
    var output_text = '<h3>Record Title Ownership</h3>' + concatenate(tables, "<br>");
    // Return the output text as the result
    return { type: 'text', text: output_text };
TKSHEP
@NorthSouthGIS  How would I bring all the related records with a table that looks like below. Using the 1st row of each record that is related to features using the 1 of # of records to each feature (repeating records) ?  I hope I am clear with my question.
Marshal
I don't fully understand your question, but you might want to take a look at the code I shared.  It iterates over potentially multiple related record "groups" and builds tables for each of the "groups", which is what your screenshot appears to represent.
hamini
Thanks so much for posting this. It was very helpful.
