disable Scroll wheel zoom embedViewer
9686
17
04-01-2011 12:43 PM
ChrisSeeger
New Contributor II
With ArcGIS.com you can get the iframe code to embed the viewer in your own HTML page.  I was wondering if there was a way to disable the scroll wheel zoom by passing a parameter in the URL string?
KellyHutchins
Esri Frequent Contributor
You may want to post this as a separate question in the Story Maps‌ place.
David_Roth
Anyway, i have try kelly's iframe settings but it does not works for me. It looks like it works only for simple maps but does not works with maps embed in Arcgis story map applications like this one for example : The Age of Megacities
KellyHutchins
David,
The url parameter to disable zoom when scrolling is not available for all templates. If you are hosting the Storymaps template on your own web server you can update the code to disable scrolling using code like this:
this.map.disableScrollWheelZoom();
jdcayetano
New Contributor II
I have this html code of the story map I did. How will I disable the auto scroll wheel zoom?
<iframe
width="100%" height="95%"
scrolling="no" marginheight="0" marginwidth="0"
src="https://crsorg.maps.arcgis.com/apps/SimpleViewer/index.html?appid=93417eb1a55248c9bf54768b379d0578&e..."
</iframe>
AJ_devaccount
Hi @KellyHutchins , is disable scrolling possible in an embedded web app? It's created using the App Builder
KellyHutchins
Which app are you using? Which app builder?
AJ_devaccount
@KellyHutchins it's a web mapping application using the Web AppBuilder. Hopefully the below image helps. I've included it as an iframe on an ArcGIS Hub page.
KellyHutchins
I'm not sure about disable scroll support in Web App Builder. There is the a esri community space for the Web App Builder I bet someone in that space would be able to answer.
