Disable "Get Directions" in pop-up?
4981
11-19-2014 02:21 PM
StevenJett
I understand that the "Get Directions" link in ArcGIS Online pop-ups is only visible when an individual within the organization is signed in. I'm wondering if it's possible to disable it for signed in users as well? There are times when the point represents a generalized location, so getting directions is not only meaningless, it's misleading.
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Steven,
Go to the web map and click 'Edit'.  Scroll down and you can uncheck 'Routing'.  This will disable the 'Get Directions' option.
Note:  I believe this option will still be available in the web map if you are an administrator.
AJM
Has this option moved? I am trying to get ride of the direction option in the pop up but cannot figure out how.   My data is in the ocean, so an option for directions is ridicules
