Did I break ArcGIS online?
4676
9
05-15-2015 12:11 PM
EricGreen
Just last week I was able to create a new map on ArcGIS.com and add data from here:
TravelTime/TravelTime (MapServer)
And it created a nice map. Now when I try, I get a "taking a long time to respond" warning followed by an error saying it cannot be added. I don't think I did anything to our ArcServer. I asked a few other AGO users to try and they saw the same results. I rebooted our server. I can add the same service to ArcGIS desktop with no trouble. Finally I tried a completely different server:
Folder: Utilities
It does the same thing. Am I doing something fundamentally wrong or did I break the Internet?
Eric
ChrisWhitmore
Eric, is your organization SSL only? That would explain it.
EricGreen
I assume this was a bug. It seems to be resolved now. Did anyone else see this behavior?
EricGreen
Okay, that was short lived. It is back again.
XanderBakker
Esri Esteemed Contributor
It seems to be drawing just fine:
Is there anything in the logs of your ArcGIS for Server?
ChrisWhitmore
Hi Eric, something to check - does the layer only fail to draw when the map is accessed over https? It doesn't look like the Folder: Utilities  supports HTTPS (and the initial link you posted also wouldn't over port 6080).
Chris
EricGreen
Xander,
How long ago did you try that? Does it work now? It was working at some point this morning.
Chris,
I have tried with and without the port. I am no longer trying the utilities feature. That was just a test. I am trying:
I log into arcgis online and create a new map and add the above link (with or without the :6080).  The I see:
For a brief moment this morning, the same steps worked fine (as it did for me a few weeks ago). If anyone can add this layer right now, then it must be something I am doing.
I really appreciate this help.
Eric
EricGreen
I do see some severe log items:
XanderBakker
I just did another test and although it takes several seconds to respond  the service can be added to the web map and shows after zooming in. I have included the PSR recording of the steps, which also lists the time for each step. Sorry for the mixture of Dutch (OS) and Spanish (AGOL account) in the recording...
EricGreen
I found that by logging out of my organization's AGO and trying my personal one that it all works fine again. I think this will work for now, but I may need to contact ESRI as to why it won't work for my organization.
Thanks for all the help folks!
ChrisWhitmore
