Description from domain is not shown in table
908
02-26-2013 02:17 AM
Mihai_DorinNedelcu
Hi All,
I have a service published in AOL for organisations, from an internal server (ArcGIS server that publishes the MapServer service in not public on Internet)
One of the fields in the published layer is a field with a domain associated.
In AGOL, when show table, apears only code value, not description value
In picture bellow, instead of DEL_P (code value), should be description value
Anybody knows why domain description value is not showing?
Thx
[ATTACH=CONFIG]22165[/ATTACH]
StaceyCrowe1
Did you figure out why your domains are not showing in the table?
AndrewDuff
did either of you find this out?  thanks Andy
JessicaViera-Atwell
I have ran across this myself on more than one occasion.  Unfortunately I have yet to figure out a way around this problem.  What makes it even more frustrating is that these Coded Domain values will appear one time but the next time the service is updated you may get the descriptions.  The only fool proof way around this that I've found up to date is to created additional fields in the schema to store the descriptions and config popups and tables on AGOL accordingly once your web services have been created.
HarmRusscher
Do you still not have a solution to this problem? I encountered the same problem. I would like to use the descriptions in a dropdownlist in AGOL filtering. It is working for one field with coded domains (text) not in another, exactly the same one.
