Deleting multiple accounts or entire group
2202
01-14-2021 08:01 PM
AbuBadruddin1
How can I delete all the accounts from last year's class using ArcGIS Online? I can only delete one by one after deleting their contents & licenses! There got to be a way to delete all 30 students together or the entire group!
Tags (1)
by Anonymous User
Not applicable
Hi @AbuBadruddin1,
Using the Python API you could do them at once.
Make a custom role to tage them for deletion, then follow the process here - https://community.esri.com/t5/arcgis-api-for-python-questions/batch-deleting-users-based-on-a-role/m...
DanPatterson
MVP Esteemed Contributor
see Manage members—ArcGIS Online Help | Documentation
under Delete Member (s)
I am pretty sure... but read it all
... sort of retired...
AbuBadruddin1
It says how to delete a member!
DanPatterson
or Disable members if multiple members are selected
You can select up to 100 members at a time. The selected set is maintained while you search and filter all the members in your organization, even across multiple pages. If necessary, click the members selected drop-down menu to review and revise your selection once you've modified your initial search or filter.
Not the part I read
by Anonymous User
Not applicable
Hi @AbuBadruddin1,
AbuBadruddin1
Thanks. I will try it with some time in hand!
