Customizing color ramps in new Map Viewer
2402
09-13-2023 04:57 PM
LisaBenvenuti1
Is it possible to customize the colors in a pre-existing color ramp? Or create a custom color ramp? I need to color population class breaks in different layers to match the same color value in both layers regardless of what the top value is.
RussRoberts
Esri Notable Contributor
You can define the color for classed values by clicking on the color swatch in Map Viewer. We do have plans to support the following but not coming in an upcoming release:
- customizing existing color ramps for other cases like the unclassed
- publishing your own color ramps with web styles
RussRoberts
SheilaV
I want to bump this thread to see if 11.4 or 11.5 now support customize color ramp symbology
RussRoberts
Still on our roadmap. Hoping to get to it in the releases next year where the unclassed color ramps can have a customization option. If you have a usecase that you could add to make sure its lining up with the scenarios we have mapped out that would be helpful thanks!
LisaBenvenuti1
Thank you, I've been trying this, I've seen this response before. It wasn't working at all until I realized that I have to be the owner of the layer. Thanks!
FourCornersMapping
I need this too, and classed values won't work because I need DRA. I'm trying to make higher elevations appear white and I need a blue to white color ramp with customizable stops and he ability to adjust transparency at each stop. Just like in Pro, but in AGOL. Please and thank you. 😁
