Customize the "Number of Features" Label text for a layer with clustering
571
04-28-2022 09:53 AM
RobertoRossi
In Map Viewer I have a point layer with Clustering Enabled.
The legend shows a Number of features description.
How can I customize the "Number of features" text?
I supposed it should be possible from the Clustering > Clustering Label > Label Field, and then working with Arcade, but I'm not able
This is the Arcade code I have if I chose the </> button:
$feature["cluster_count"];
var value = $feature["cluster_count"];
var num = Count(Text(Round(value)));
var label = When(
num < 4, Text(value, "#.#"),
num == 4, Text(value / Pow(10, 3), "#.0k"),
num <= 6, Text(value / Pow(10, 3), "#k"),
num == 7, Text(value / Pow(10, 6), "#.0m"),
num > 7, Text(value / Pow(10, 6), "#m"),
Text(value, "#,###")
return label;
Is there a way to obtain a customized text?
3raan
New Contributor III
In the Cluster menu, select the "Cluster fields" button.
Then, select the "Number of features" field and rename.
3raan
New Contributor III
RobertoRossi
Thank you very much @3raan for the solution!
simpler than I thought
Roberto
