I am trying to remove or change the wording that appears in the layout/data frame when using the print widget in a web app. Does anyone know where I would be able to change that information?
In Map Only: In A4 Landscape:
I am working on creating a custom print layout but that line of text still appears.
Thank you
Where did you change the credits? In the original map document of the service you're printing?
According to the page on printing and exporting, this is set in the layout view. Since the layout view comes from the mxd template in the print task, you may need to create your own template so you can modify those elements as needed.
If these are custom templates, did you check the credits on the map document used for the print template:
Or the credits of the data frame?
The snips in the original post were not from custom templates. But I did change the credits for both the data frame and map document and that did not replace the original wording. Thanks though!
Thank you! I got it figured out!
