Creating a robust web form application to collect data with AGOL
2079
09-07-2016 06:44 PM
PriyanthaPallegama
Hi All, I have a requirement of creating a web map based application to collect field information. I already looked into Collector for ArcGIS which gives some similar functionality. However,  I would like to know is it possible to use AGOL to build a robust web application to query information based on location to pre-filled a web form and add more capabilities to the same web form such as attachments, offline saving, etc. without using a separately hosted website? If so, what is the best approach for this?
DerekLaw
Esri Esteemed Contributor
Hi Priyantha,
Have you looked at Web AppBuilder for ArcGIS, which enables you to create custom mapping apps for the web without programming?
Regarding collecting web forms, please take a look at Survey123 for ArcGIS, which enables you to collect field data based on forms.
Both apps are included with your ArcGIS Online organization.
Hope this helps,
PriyanthaPallegama
Hi Derek,
Thank you for your prompt response. This was helpful for me to heading the right direction as I am new to AGOL.
I appreciate if you can provide some direction for pre-populating some fields of the web form by querying AGOL webmap layers based on location.
Thanks heaps,
Priyantha
DerekLaw
Hi Priyantha,
If you are referring to the forms in Survey123 for ArcGIS when you say "web form" above, this is not a supported workflow. The surveys in Survey123 are NOT meant to have their questions pre-populated with content from feature layers in ArcGIS Online. Please review the help doc,
Survey123 for ArcGIS | ArcGIS
Hope this helps,
