Creating a Hatched Symbology With 2 Colors
2182
03-15-2024 11:22 AM
edward33
I created this symbology in ArcGIS Pro. They are based off 2 different attributeshashed_symbology.PNGsymbol_property.PNG
AttributeA is expressed through the solid fill which I created 4 different symbology classes from
To show AttributeB on top of AttributeA I added a hatched fill which I then added expressions for the color and line width based on AttribueB
Of course when I uploaded this layer to AGOL it lost the custom symbology. I know I can control symbology more using an expression in AGOL but I was wondering if there is a way to get this same hatched effect with a color underneath (not just transparent) in AGOL.
There is going to be quite a few different layers that are like this- so creating a separate layer to show this won't work. The layer also already has a large number of fields so I am really trying not to add more fields if possible.
RussRoberts
Esri Notable Contributor
When sharing the web map or layer make sure this option is unchecked in the sharing dialog.
Here is a quick sample I made driving the color from a field with rgb values. Make sure when configuring the attribute driven symbol property the scripting language is set to arcade.
Sample map published from Pro 3.2
https://www.arcgis.com/apps/mapviewer/index.html?webmap=ec56b45e26694a8ea25f7fcd27325dc5
edward33
In the link you sent I noticed the hatching only has one color and then transparent- I want there to be 2 colors with each color representing a different field. Not sure if that is possible in the online environment
RussRoberts
can you share a Pro project and I can take a look? thanks!
