Configure Pop-Up to show related records in new map view
1614
03-02-2022 02:10 PM
Sammy_SalmonNSEA
I have a polygon layer with a 1:M relationship class to an associated table. The relationship class functions great and I am able to access the 'related records' from the pop-up in both ArcPro and the ArcOnline Map View Classic. But when I toggle the pop-up in the new ArcOnline map viewer there is no option to view the related records. I have gone through the pop-up configuration sidebar and can't seem to find an option to include this data. The table does appear under the 'tables' tab on the left hand sidebar.
Any help getting the associated tables data to appear in the pop-up would be great. Thanks!
SCURTI
I have the exact same problem.  No way to see the related table in the new Map Viewer.  Online help (Configure pop-ups (Map Viewer)—ArcGIS Online Help | Documentation) for related tables (bottom of page) says to "2. Click Add content and choose Related records.", but it does not show me that option in the new Map Viewer.  I can configure the pop-ups for the related table, but no way to show it or see it in the actual pop-up.  The classic version has a link at the bottom of the pop-up window that allows you to see related records.  Where is this functionality in the new viewer?
KeithLomis1
Have you heard or seen an update on this?
Laura
by MVP Regular Contributor
Did you configure the popup on the parent layer to show the related record?
You should see this on the parent layer.
GviliOrr
im using  formated text ,
with arcade  read all the relevant related data  to text string
and then disply the data
var relatedRecords = FeatureSetByRelationshipName($feature, "yourRelatedTable");
var sortedData = OrderBy(relatedRecords, 'sampling_date DESC');
if (Count(relatedRecords) == 0) {
    return "⚠️  No water quality data available.";
var outputText = "🔬🧪 Data\n" + "═════════════════════════════════════" + "\n\n";
for (var record in sortedData) {
    var samplingDate = Text(record["sampling_date"], "D/M/Y");
    outputText += "📅 " + samplingDate + "\n";
    outputText += "────────────────────────────" + "\n";
    outputText += "• Chloride ....................... " + IIF(IsEmpty(record["cl"]), "N/A", Round(record["cl"], 3) + " ppm") + "\n";
    outputText += "• SAR ............................... " + IIF(IsEmpty(record["SAR"]), "N/A", Round(record["SAR"], 3)) + "\n";
    outputText += "• Sodium ......................... " + IIF(IsEmpty(record["na"]), "N/A", Round(record["na"], 3) + " meq-L") + "\n";
    outputText += "• Calcium ........................ " + IIF(IsEmpty(record["ca"]), "N/A", Round(record["ca"], 3) + " meq-L") + "\n";
    outputText += "• Magnesium ..................." + IIF(IsEmpty(record["mg"]), "N/A", Round(record["mg"], 3) + " meq-L") + "\n";
    outputText += "• Total Nitrogen (as N) ...  " + IIF(IsEmpty(record["n"]), "N/A", Round(record["n"], 3) + " ppm") + "\n";
    outputText += "• Nitrate as N .................. " + IIF(IsEmpty(record["no3"]), "N/A", Round(record["no3"], 3) + " ppm") + "\n";
    outputText += "• Potassium ..................... " + IIF(IsEmpty(record["k"]), "N/A", Round(record["k"], 3) + " meq-L") + "\n";
    outputText += "• Sulfate ........................... " + IIF(IsEmpty(record["so4"]), "N/A", Round(record["so4"], 3) + " ppm") + "\n";
    outputText += "• Phosphates .................. " + IIF(IsEmpty(record["po4"]), "N/A", Round(record["po4"], 3) + " ppm") + "\n";
    outputText += "\n";
return outputText;
