I've created this map through Experience Builder. I'm able to configure the contents of the Pop-up within map viewer. However, is there a way to change the colors of the pop-up? The default colors make the contents practically illegible. (Please no coding suggestions...that is over my head 😸)
Thanks for any advice!
DMV! 🙂
Not on the experience builder team but from my use you can adjust the styling with tweaking the colors used I think you need to tweak the color styling themes here:
https://doc.arcgis.com/en/experience-builder/build-apps/change-app-theme.htm
Thanks! I took it off the organization's theme and was able to edit it enough to be legible.
