Clip to shape in ArcGIS Online
1822
11-28-2019 12:12 PM
AnuSawant
Occasional Contributor II
Is there any way I can use Clip to shape setting in ArcGIS Online.
I have received a raster and want to show area only inside the polygon (masked layer) I have tried using a clip to raster tool but then it doesn't clip exactly to the area. Any help much appreciated.
Anu
JuanSantos
Hi Anu Sawant
I leave you the following link:
Also in the same tool you used you can go to "Environment Settings" _ Processing Extent and select the extension you want.
Hope this can help you.
I leave you a capture.
