chrome popup date field doesn't display
2973
13
03-08-2017 03:20 PM
TrentSohnle
I have a popup display that reads a datetime field in a csv file. The field (Discovered Date) displays in Firefox and IE but not Chrome. Any idea how I would go about fixing this?
Here is the map in question. Click any pin to see the popup in action. Must be in Chrome to reproduce the bug.
Status Map | AAF - Agriculture and Forestry
TrentSohnle
Also, how do I move the region overlays to the back. Built in arcgis online.
Thanks.
AdrianWelsh
MVP Honored Contributor
Trent,
That sure is odd. I was able to reproduce the issue like you stated. Can you share a link to your original web map in ArcGIS Online?
TrentSohnle
AdrianWelsh
Huh. Same issue. I wonder if the most recent update of Chrome is causing issues for AGOL. My current version is:
Version 56.0.2924.87
This may be worth reporting a bug to Esri about.
TrentSohnle
Thanks for your help on the issue Adrian. I created a comment here:
https://blogs.esri.com/esri/supportcenter/2007/09/14/bugs-online-is-here/#comment-1936
I think my question is still in moderator approval status. Should be up shortly I'm thinking.
Not sure if that's the right place or not. Let me know if you have another place you think I should report it to.
Trent
AdrianWelsh
At this point it might be best to contact your local esri rep about this and see if they can reproduce this. Unless someone on this board will log a support ticket for you (which happens but not often).
KellyGerrow
Esri Alum
Thanks Trent and Adrian.
Adding some people to help with this kpinkston-esristaffKCullen-esristaff
-Kelly
TrentSohnle
Hi we coded the cell to be datetime and it works but whatever it was initially ( I think time field) it wouldn't work.
I will find out on Monday
Trent
Get Outlook for Android<https://aka.ms/ghei36>
by Anonymous User
Not applicable
I can get a Support Case created. Could you direct message me your contact information (email and phone) so an Analyst can reach out to you directly.
