Change individual text colors in Arcade Element
2245
08-29-2023 01:20 PM
Ed_
by MVP Regular Contributor
Based on the code below how can I change the colors of certain words individually.
Purpose: To learn how to change colors in Arcade element.
// Create a variable that the FeatureSet of intersecting feature attributes
var building = FeatureSetByName($map, "BuildingFootprints_Clip")
var intersectLayer = Intersects(building, $feature)
// This variable will be repeated multiple times in the code
var popup = '<h2>Building</h2>';
for (var f in intersectLayer){
   popup += `<b>Area:</b> ${f.AREAFT} <br><br>
  <b>Length:</b> ${f.LENFT} <br><br>
  <b>ID:</b> ${f.ID} <br><br>
Desired output:
Area: Value
Length: Value
Question | Analyze | Visualize
KenBuja
MVP Esteemed Contributor
This will make Area red
   popup += `<b><font color = "#ff0000">Area</font>:</b> ${f.AREAFT} <br><br>
  <b>ID:</b> ${f.ID} <br><br>`
ArmstKP
Ed_
Thank you for the quick response and for providing the link 🙂
KenBuja
Ed_
Thank you Ken 🙂 so can <font color = "HEX code"> also applied on "Length", "ID" and the heading "<h2>Buidling<h2>?
KenBuja
Yes, you'll have to add <font color = "HEX code">text</font> to each item you want with a separate color
