Cannot upload shapefiles or open shapefiles in a map in ArcGIS Online
2710
6
05-21-2014 10:31 AM
KrisMoore
Is anyone else having problems with uploading or opening shapefiles in ArcGIS Online???
MichaelThompson2
I'm not having any issues. Your shapefiles are compressed, right?
RaymondHuang
You might be facing one of these limitations:
Compression formats other than a .zip archive are not supported. Make sure you are using .zip, not .rar or others.
Files containing more than 1,000 features(records) cannot be added to a map.
The following features are not supported: multipatch or multipoint geometries, geometries that cross the dateline, or self-intersections in polygons. Shapefiles with these features cannot be added to a map.
If you are trying to drag your Shapefiles in like in ArcGIS Explorer Online, no it cannot be dragged directly onto the ArcGIS.com map viewer; you must use the Add button in the map viewer.
Let us know what was the cause. Hope it helps.
Cheers,
Raymond
MattKennedy
kmooregis,
How are you uploading the shapefile to ArcGIS Online?  If you are in a map and clicking 'Add' > 'Add layer from file' then you will have the limitations (1,000 feature max, etc...) that others have mentioned.  To avoid these limitations, upload your shapefile to ArcGIS Online as a feature service.  Here's how:
1. Go to 'My Content'.
2. Click 'Add Item'.
3. Click 'Choose File' and browse to your zipped shapefile.
4. Check the box that says 'Publish this file as a feature layer'.
5. Set the title and tags as you wish.
6. Click 'Add Item'.
The above procedure will create a hosted feature service from your shapefile, which you can now use in any map you want.  On the other hand, adding a shapefile directly to a map only makes that layer usable in that one map, and it throws limitations at you.  Always upload data to your 'My Content' area of your subscription.  It's a much better way to get things done.
Good luck,
Matt
BimallNaidoo1
New Contributor II
Hi
I followed this workflow successfully with a few large datasets and have now experienced the same problem with a dataset that has 69 000 features. Is there a size/feature limit that can be uploaded?
Thanks
Bimall
SteveWashburn
I have added a kmz track file via add to my content but I don't get the "publish this..." check box and when I go to a map all that is shown are the start and end points.
What am I doing wrong?
Steve
TonyPistilli__GISP
New Contributor II
kmooregis,
Good luck,
Matt
I am having the same problem! Very frustrating.  I have uploaded parcels in excess of 1000 features in the past using the above method with no problems in the past. Now, since upgrading to 10.2.1 I can no longer do this.  Can someone from ESRI help out here? Thanks
