Cannot share 'Esri default basemaps' to custom basemaps group
723
11-03-2020 06:21 PM
JackSilburn
New Contributor III
Our organisation has aerial photography, which we want to include into our 'basemaps' selection. We also still require the Esri default basemaps to be selectable.
I am following this article here:
Create a custom basemap gallery for your organization
In the final steps, you can chose to share the Esri defaults with the custom basemaps group. The button is called 'Share vector basemaps':
However, this button functionally does nothing when pressed. Inspecting my Chrome browser actually shows an error, upon button press:
dojo.js:516 Uncaught Error: dijit._TemplatedMixin template:!text
at Object.<anonymous> (dojo.js:516)
at dojo.js:46
at dojo.js:521
at String.replace (<anonymous>)
at Object.g.substitute (dojo.js:520)
at Object._stringRepl (dojo.js:516)
at Object.buildRendering (dojo.js:517)
at Object.create (dojo.js:301)
at Object.postscript (dojo.js:300)
at new <anonymous> (dojo.js:150)
I don't know if this is the cause or related? I can't find any articles whereby people are experiencing the same issue.
Any help is appreciated,
Thank you
Christina10ant
Did you find a solution to this issue? I am having the exact same problem. When I click the "Share vector basemaps" button I get the same error in my Chrome browser:
at Object.<anonymous> (dojo.js:535)
at dojo.js:47
at dojo.js:540
at Object.h.substitute (dojo.js:539)
at Object._stringRepl (dojo.js:535)
at Object.buildRendering (dojo.js:536)
at Object.create (dojo.js:320)
at Object.postscript (dojo.js:319)
at new <anonymous> (dojo.js:154)
Thanks
Christina10ant
Looks like the issue is with the settings when you create the Group. I think it has to do with the "What items in the group can it's members update?" When it was set to "All items (group membership is limited to the organization)" I got the error.
I recreated the group with "Only their own items" selected instead and was able to share the ESRI basemaps.
My group settings are in the attachment.
Cheers
