Can't find Style Manager
3690
06-17-2015 10:53 AM
CaroleKirk
I need to add turn arrows to a map. I can't find the style manager dialog box.
Help.
LizD_Arcy1
Hi Carole -
In ArcMap, go to  > Customize > Style Manager
To add or create new Styles, click the Styles... button.
CaroleKirk
Thank you that is very helpful. I added transportation but did not find turn arrows for streets. Do you know where I find those and how to add to map?
I had found some arrows in the picture library under styles when I got desperate to get this done but it is left and right and I need also north and south and a multiple one and I can't rotate them.
LizD_Arcy1
Hi Carole,
In the layer properties window > Symbology tab > Single Symbol > Click on Symbol > In Symbol Selector, make sure that you have the Transportation style added (click on Style References button, check on Transportation) > Edit Symbol > Type: Marker Line Symbol, Marker Line Tab > Symbol... button > Search for "Arrow"
You should see the Arrow options available from the Transportation Styles.arrow.JPG
